Precision tool case wood types
Results 1 to 12 of 12
    Mar 2007
    Milwaukee
    420
    345
    188
    Default Precision tool case wood types
    I have a nice piece of Sapele that i was considering making a few tool cases out of. The cases will be for precision ground blocks and measuring equipment.
    Perhaps it was here i read that certain woods if used in a case would promote rusting. I do plan to isolate the ground tool from the wood with felt.
    Is Sapele safe to use in a tool case? Are there any other woods to stay away from?
    Sep 2005
    Northern California
    832
    101
    I have my fathers Starrett 123 calipers and they've lived for 60 years in the factory Sapele case..... bare wood on the inside AFAIKT. No discoloration yet!
    Jul 2007
    UNITED KINGDOM
    4,853
    2605
    2361
    I believe that Sapele is safe. The one to be careful with is oak. That needs to be varnished or oiled to avoid rust on contacted steel.
  4. Likes stephen thomas liked this post
    Mar 2009
    5,160
    97
    950
    Quote Originally Posted by Mark Rand View Post
    Tannic acid.
  6. Likes Mark Rand, stephen thomas liked this post
  7. #5
    Mar 2010
    pacific northwest
    1,027
    6
    205
    Only one I ever made was curly Koa... back when it was cheap..
    Houses a Mit indicator, stand, and arms. no rust there, I used it for aligning shafts on boats.
  8. Likes stephen thomas liked this post
  9. #6
    Dec 2015
    Connecticut
    984
    23
    308
    I have an Interapid indicator that’s been in a little mahogany case for a couple decades with no issues. I made it from two small pieces of scrap deck boards, routed out like Starrett used to do. A couple short pieces of 1/8” drill rod align and keep it together
  10. #7
    Mar 2007
    Milwaukee
    420
    345
    188
    Thanks for all of the quick responses!
    I do like to use Mahogany for a lot of projects. It is tough to justify for a tool case. The piece of Sapele i found is clear and has a nice straight grain with no run off. I didn't realize Starrett used Sapele.
  11. #8
    Sep 2002
    Lawrenceville GA USA
    6,239
    802
    1356
    Waxed wood protects tools as it doesnt hold moisture against the tool. The felt can hold moisture so if you are in a humid area you may want to just go without the felt.
    Charles
  12. Likes stephen thomas, MCritchley liked this post
  13. #9
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,050
    4131
    3867
    This one's for Stoneaxe,
    "how many toolboxes....."
    Curly Koa floor i did minor repairs to before Christmas.
    smt
  14. Likes Joe Rogers liked this post
  15. #10
    Apr 2019
    New Jersey
    60
    I try not to have direct contact between wood and the tools. Instead I make a foam insert.
    I’ve been using various types of cypress and mahogany for the cases. I suspect mitutoyo ‘made in Brazil’ cases are Spanish cedar (iirc this is a type of mahogany).
  16. #11
    Mar 2007
    Milwaukee
    420
    345
    188
    I might use a sticky back foam in place of the felt. Would the foam hold moisture as well?
    I wonder if there is a felt or foam that holds oil or that wouldn't hold moisture against a precision part.
    Perhaps a permawick type of material.
  17. #12
    Apr 2019
    New Jersey
    60
    I use material that is commonly sold for use with tools. So far, so good. One of them is Kaizen foam.
