PeteM
- Jan 15, 2002
- West Coast, USA
Ten plus years ago I ordered 8 doors for a shop addition from our local lumberyard's door manufacturing facility. I've had problems with half of them. The dry rot in at the bottom of two jambs, I can easily enough repair. The question is what to do with thin glue-joint splits running the entire length of the jamb? This is a jamb that gets both rain and sun.
Apparently the way they built doors for 6" walls was to take a 4" door and extend the jamb and sill by 2". That's where the full length cracks are -- right along that vertical glue line where it faces the morning sun. These are double doors and otherwise sound - no movement, still square and solid. But the inward swinging door jambs are exposed to the weather -- and the crack opens and closes with wet and dry weather. While the full length crack is tiny, simply re-priming and painting with a full latex (some give to it) wasn't a fix.
One idea is to run a saw blade through the crack and use a filled epoxy. Essentially re-glue it with epoxy and hope it holds. I haven't had luck with that the one time I tried it on a square wood column.
Another is to run a tiny dovetail bit the length of the crack and fill it with body putty. So, it would be keyed in. Dry rot repairs with body putty have held up well for years, but I don't have experience with so much wood/putty length and extremes of moisture and sun.
A third idea is to find some very thin material and just adhere it over the entire exposed part of the jamb. Anything that will take paint, moisture, and sun. Maybe if I can find a fiberglass panel about 4" wide by door height tall and use a waterproof contact cement?
Anyone dealt with this before and have a fix that will hold up?
