Steve@Reliance
Hot Rolled
- Dec 27, 2006
- Milton Ontario Canada
Next door a freind of mine has a cabinet shop. My dad used to own a business that made several wood products. I have known many woodworking shop owners as well. Since I have been around machines I have wondered why the woodworking machines never have any measurable form of adjustment. For instance, if I walk over to a bridgeport and turn a handle I can control how far I move the table by counting the number of graduations or looking at a readout. With the exception of the shops utilizing CNC routers, everybody working with wood is still using tape measures to adjust or set their machines. Now this may be accurate enough for wood, but I can't believe this is the fast way to do things. I watch these guys make a door panel for instance. If the door should be 15x24, it might be 15 1/16"x23 15/16" by the time he's done. The parts all fit together and the door looks fine. But you might not be able to mix the parts with the other doors for that set of cabinets. The guy next door does uppity level stuff and has done it for a long time, but if I suggest he put a readout on the tablesaw fence, he evasively mumbles something about it being to expensive and "it wouldn't work anyway". The methods a lot of woodwokers use to make stuff would make a metalworking guy pull his hair out. I can't understand why none of the machine builders utilize things like lead screws etc. so you would know how big you are making your stuff or how much your changing it. Just to be able to do repeatable setups seems like a no brainer to me????????????
