Slot mortiser bits/drills.
Likes Likes:  0
Results 1 to 9 of 9
    Dec 2010
    Uruguay
    75
    22
    Default Slot mortiser bits/drills.
    First time for me at this forum.
    I'm looking for a US-source for slot mortiser drills.
    No matches were found as a result of a search in the Forum for "slot mortiser drills" so maybe I'm using the wrong name.
    I've tried Amazon but they only have Essedo drills for left-hand turning (CCW) machines and I need RH bits.
    I contacted Guhdo US but they would not answer.
    Ideal drills for me would be carbide-tipped, not solid carbide, with 16mm shanks, 10mm to 20mm assorted cutting diameters. Shank diameter must be 16mm, cutting diameter is OK in English units.
    Can anyone suggest a vendor in the US that can supply those?
    Thanks!
    Feb 2013
    Greenfield, MA
    275
    48
    46
    Why not obtain that sort of drill from Europe where they are readily available (though not in fractional inch sizes)? Selection in the US is rather marginal - I haven't been able to find any suppliers of late, though I think Forest City Tool made them in the past at least, and maybe Onsrud, though the current online catalogs from either manufacturer don't appear to list them.
    EDIT: look on Forest's site under 'Metric Boring Tools' - but all in only 10mm shank. They may be willing to make something custom for you, but it won't be inexpensive.
    Dec 2010
    Uruguay
    75
    22
    Thanks for the suggestion! 10mm shanks are way too thin, and my mortiser's collet will only accept 16mm. I'll try to get those drills in Europe.
    Dec 2012
    Se Ma USA
    1,497
    115
    840
    Last I knew Forest City made them to order. Spec shank and dia. Mortiser bits are different than drill bits though. You can do both with either but best results with the correct tool. I have used a lot of deep single flute Onsrud cutters to Mortise.
    Aug 2018
    I bought a 5/8" and a 3/4" from Laguna Tools. They do sell horozontal slot mortisers so they have to sell cutters. The cutters work fine. The machine not so well. They have 1/2" shanks with four points and will run either CW or CCW.
    Joe Carpenter
    Apr 2007
    mays landing NJ
    502
    451
    139
    Is it possible to change the collet to 5/8" ,close to 16mm. If so then any number of milling cutters can be used.
    Jun 2008
    TN
    1,558
    330
    251
    High helix carbide side cutting end mills would work. You would probably have to have the shanks reduced to 16mm for the larger than 16mm cutters. For the smaller sizes, collets might let you use the smaller cutters in you machine.
    Dec 2010
    Uruguay
    75
    22
    I´ve tried carbide end mills and also carbide-tipped router bits, they are easily available and work beautifully but only for shallow mortises, they just don't have the length for a deeper (4 inch) mortise which requires a 5" long bit including the shank.
    The shank's diameter is not really a problem, collets that will fit are easily made.
    Dec 2010
    Uruguay
    75
    22
    Quote Originally Posted by Joe Carpenter View Post
    Joe Carpenter
    The Laguna website doesn't mention slot mortising machines or bits; am I looking at the right website?
