source & type for flat belt for multi spindle drill
Results 1 to 14 of 14
    Aug 2007
    GA
    819
    148
    Default source & type for flat belt for multi spindle drill
    I've got a multi spindle drill for drilling shelf adjustment pin holes and I need a 63" x approx 1-1/4" wide, very flexible, but low stretch belt. I see a lot of conveyor type belts which would be too stiff but without a sample to put my hands on I'm not sure what I need. I would think something with urethane over a fabric core would work but it needs to be around 1/16" thick or a little thicker but less than 1/8" anyone know a good source? rollers are about 1-1/2" dia
    Dec 2008
    minnesota
    184
    37
    175
    McMaster-Carr page 1138
    Aug 2007
    GA
    819
    148
    That was actually the first place I looked. The fabric reinforced rubber ones sound awfully thin at .03", I'd love to use the non reinforced orange weldable urethane but I don't know if they would resist stretching enough to put enough tension on the belt to avoid slipping. Any thoughts there? I've never used this machine and am not sure how tight the belt will need to be.
    Sep 2006
    Nevada
    373
    24
    95
    I have used the made to order flat belts from McMaster-Carr on my wood shapers and have never had a problem. I believe they are the .03 thick and am using 1 1/2" wide on 3 HP motors.
    Apr 2004
    Modesto, CA USA
    7,609
    1348
    South Bend lath owners will tell you to use a automotive serpentine belt and lace it through the grooves.
    Bil lD
  6. Likes Joe Rogers liked this post
    Aug 2007
    GA
    819
    148
    that would be too thick unless I could remove the ribs, but if there is a ribless version that would be great. Is there?
    Aug 2006
    Virginia
    618
    890
    357
    They could be skived off. There are no reinforcement plies in the ribs. Would be easy with jigging but tedious without.
    Joe
  9. #8
    Aug 2007
    GA
    819
    148
    I can get a 630-k-8 (63" x 1-1/8) automotive 8 rib serpentine belt for $14.50 delivered, which is $50+ less than the thin ones from mcmaster. I have a sanding drum that will work in a drill press and can clamp a platen in the vise, maybe I'll experiment with some belt laying around here unless there is a better way. The machine will accommodate an endless belt, I just need to remove all the belt ribs
  10. Likes Joe Rogers liked this post
  11. #9
    Jul 2006
    rochester, ny
    2,035
    445
    598
    Your belt will be in contact on both sides, does the back of an automotive belt grip as well?
  12. #10
    Nov 2007
    E-burg MD USA
    594
    102
    TomJelly, sir
    Try "Baltimore Belting" they will hook you up with what ever your little heart desires.
    Hope this helps ya out
    Stay safe
    Calvin B
  13. #11
    Mar 2009
    Eureka, CA
    4,041
    881
    1514
    Quote Originally Posted by tomjelly View Post
    Those are the belts to use. They are skinny, but stronger than heck..you will not be able to break them with any normal tensioning system.
    Stuart
    PS..After actually looking at the picture you posted of the machine it would appear to me there is going to have to be some serious belt tension as the intermediate pulley have less than 1/2 of their diameter in contact with the belt. Having said that, the 'made to order' .030 belts offered by McMaster would be up for the chore.
  14. #12
    Aug 2006
    Virginia
    618
    890
    357
    Yes there are pulleys on a serpentine accessory drive system that are powered by the smooth side.
    Joe
  15. #13
    Oct 2019
    NICARAGUA
    106
    41
    Automotive serpentine belt is what i would try. They like lots of tension, and dont stretch much. Cheap and as close as the nearest autozone. Make a little jig with a utility knife blade to cut off the ribs.
  16. #14
    Aug 2007
    GA
    819
    148
    I got a .03" mcmaster belt and its strong enough but surface is slick nylon on both sides so it just slips, even under great tension. I tried belt dressing and that increased the friction but not enough, a waste of $60, I may try the automotive belt next
