Speedex metal lathe or wood lathe?
Results 1 to 7 of 7
    Mar 2021
    Kansas
    10
    Default Speedex metal lathe or wood lathe?
    Saw this on Craigslist, advertised as a metal lathe. I did a quick Google search and couldn't find anything about it. Is it a metal lathe or a wood lathe. And what is the long tailstock for?speedex3.jpgspeedex2.jpgspeedex1.jpg
    Sep 2009
    Phoenix,AZ
    2,142
    3480
    584
    Wood lathe or possibly a metal spinning lathe. Weird TS who knows?? I'm sure there was some reason for it though.
    Dec 2008
    Vt USA
    9,892
    1814
    3710
    With that tail stock. It is a metal SPINNING lathe.
    Or a specialty wood turning machine, but I can not imagine what type of production turning would require that TS.
    On the other hand, a spinning lath would need to accommodate a variety of forums, but always require a firm pinch of the sheet stock by the tail center.
    I've got a smaller spinning lathe by another maker. It comes in hand at times, but not so much for spinning sheet metal. I should give it a go !
    Mar 2021
    Kansas
    10
    Thanks, I'd never heard of a metal spinning lathe before.
    Oct 2005
    23,060
    Could be that someone hung a speedex tractor badge on it.
    Seen it done before, a good friend ran a very nice bridgeport series 2 that he hung
    a "Yamaha" badge on it, fit nicely, looked good.
  6. Likes stephen thomas liked this post
    Dec 2012
    Se Ma USA
    2,397
    190
    1328
    For sure used as a metal spinning lathe. Row of holes on the steady rest and the leverage pin appears to be taped to the steady rest.
    Oct 2020
    Michigan
    39
    Quote Originally Posted by CalG View Post
    Not just the tailstock, that steel on that bed and rest is FAR heavier than anything you'd see from a similar vintage wood lathe. The only wood lathes I've seen with steel that heavy are the ones designed for turning huge/unbalanced chunks of wood and those require a lot more height than that appears to have.
