What do wood guys use HVLP for
Likes Likes:  0
Results 1 to 10 of 10
    Jan 2006
    Brookfield, Wisconsin
    3,933
    213
    343
    Default What do wood guys use HVLP for
    For what material and application do wood finishers use HVLP for?
    I just started an Automotive painting/chassis program at local tech school. We use HVLP for auto painting as it is industry standard.
    While looking at the various brands of HVLP manufacturers, I noticed that Graco and Kremlin make HVLP guns, but I have never heard of anyone in the automotive painting world use either brand. Since Kremlin is popular with wood guys, my hunch is that Kremlin HVLP is used for wood finishing?
    Oct 2010
    Oregon
    4,924
    3982
    1775
    Can't speak to Kremlin, but wood shops use HVLP anywhere they'd use any other type of spray gear. And wood shops spray a lot of finishes ranging from lacquer to urethanes, and occasionally adhesives when working with sheet goods.
    Oct 2010
    Maryland- USA
    3,006
    1769
    1991
    I spray everything with it- two pack clears, poly, lacquers, traditional varnish.
    The down side of spraying traditional varnish is having to thin and still build film thickness.
    Mar 2009
    4,756
    87
    870
    Quote Originally Posted by Spud View Post
    Tells you something, doesn't it?
    I don't spray on wood any more. I use the Sam Maloof two stage finish method. Takes a long time for rubbing with a rag. But the result is worth it.
    Mar 2009
    4,756
    87
    870
    Looks like a Sata copy. They should throw in a free roll of Teflon tape to seal up all the air leaks.
    What is the https://www.ebay.com/p/2008hvlp-Auto...er/16026959342
    Jun 2008
    TN
    1,532
    313
    247
    I’ve painted using HVLP guns spraying latex trim paint for house trim, doors and the like. I also have a smallish Sata HVLP gun that I use for clear finishes on fuurniture and other fine finish work. It works well with varnishes and lacquers. As Triboatworks mentioned you do have to thin for a good spray pattern but I find it well worth the slight downside. I especially like the result with Waterlox as each new coat burns into the previous coat. Two or three coats gives a really nice built up finish. Really not much different from any other method because of the fine control of film thickness for each coat. Very little waste too.
    Jan 2006
    3,933
    213
    343
    So what is the reason to use HVLP gravity feed over siphon feed or pressure pot? Do you use gravity feed if it's a small job?
    And why use airless or air-assisted over HVLP?
    Oct 2010
    Maryland- USA
    3,006
    1769
    1991
    Gravity feed can run on lower cap pressure so less overspray.
    On the other hand, a cup can be fed a bit of pressure to eliminate some of that advantage while a separate pot is of course a pressure feed.
    Mar 2009
    4,756
    87
    870
    Watch those woodworker programs on PBS, weekends. Once in a while they spray finishes on their projects. It's usually a turbine with some funky spray gun. If they might describe what the painting system they are using. Anyway, they use the tools the advertisers hope you will buy.
    In my experience the spraying on plywood is not so great. Depends on the wood but I see different looking fill areas, non-uniform absorption. A hand rubbed method always comes out even and better. Takes a lot more time.
    Mar 2019
    AUSTRALIA
    10
    11
    Coming in a bit late but Graco and Kremlin are commonly used industrial painting spray gun brands. Industrial spray painting is a whole separate field to automotive or timber finishing. My shop uses Graco airspray, air assisted airless and airless. We just use what the job demands. Cheers
