I'm basically trying to make a ball end on a 3/4" shaft and keep running into an error about the G02 lines. The onboard fault checking program doesn't say what is wrong, just the line that has a problem. I've used both R and I, K syntax and still get the error. This control definitely wants I, K in absolute dimensions. I've fudged beginning X +.0005 off centerline to make sure that the start and end points are positively in the same quadrant.
I've used G02 and G03 just fine on this machine before and just can't figure out what the problem is if not just some dumb syntax that I'm too tired to see.
The machine is an old OmniTurn conversion. I'll pound sand if this is the type of thing you don't want here, just let me know.
Here it is the code - error lines in bold. Absolute origin is X=0 at centerline, Z=0 at 1" out from part face. There is a rouging pass .020 out from the final pass. Spaces added only for some readability
G90G94F100
T1
X.001Z-.9
G95F.005
Z-.9485
G02 X.853 Z-1.375 I.0005 K-1.375 (alternate R.4265)
G00X.9
Z-.9
X.001
G01Z-.9685
G02X.813 Z-1.375 I.0005 K-1.375 (alternate R.4065)
G00X.9
Z0
M30
Any insight is appreciated! Thanks!
G90G94F100
T1
X.001Z-.9
G95F.005
Z-.9485
G00X.9
Z-.9
X.001
G01Z-.9685
G00X.9
Z0
M30
