Rockbobster
- Aug 9, 2023
machine NL6000 XLM
fanuc series oi-tf
PS0325N CIOMMAND NOT IN SHAPE
im attempting to use G71 cycle to slot out key ways on the shaft work we do here but when i use g28 to send
the machine home after completing the canned cycle im getting an out of shape alarm making it seem the the cycle isnt ending?
as of right now the code runs perfectly except for faulting out in between the 2 tool paths when sent home
i tried running without the G28U0. but even then it faults on me calling out my c position and locking it.
the dimensions on the slot are irrelevant as i intend to turn it into a macro after i get this fault worked out.
also the machine wont accept the other formatting
:example:
G71U.2R.05
G71P10Q20U.03W.003F.01
at all despite it being in the programing manual formatted that way.
this code did run just have to reset and start on 2nd toolpath so the G28 line seems to be the culprit but im not sure how to avoid it
O3001(keyway program)
(ROUGH SLOT)
G0G28U0.
G0T0707
M45
G0G28H0.
G0C0.
G98M68
G97S300M13
G01X8.0 Z1.25 F30.0 (START POSITION)
G71 P100 Q200 D500 U.01 W.005 F2.0
N100
G01 W0.0 X6.388 (START OF KEY .25 CLEARANCE)
Z-10.263 (END OF KEY)
X8.0 (RETACT)
N200
M15
M46
G99M67
G0G28U0.
M1
(finish slot)
(change to on size EM)
G0G28U0.
G0T0707
M45
G0G28H0.
G0C0.
G98M68
G97S300M13
G71 P300 Q400 D500 U.0 W.0 F2.0
N300
Z-10.188 (END OF KEY)
X8.0 (RETACT)
N400
M15
M46
G99M67
G0G28U0.
M1
M30
fanuc series oi-tf
:example:
G71U.2R.05
(ROUGH SLOT)
G0G28U0.
G0T0707
M45
G0G28H0.
G0C0.
G98M68
G97S300M13
N100
X8.0 (RETACT)
N200
M15
M46
G99M67
G0G28U0.
M1
(finish slot)
G0G28U0.
G0T0707
M45
G0G28H0.
G0C0.
G98M68
G97S300M13
N300
X8.0 (RETACT)
N400
M15
M46
G99M67
G0G28U0.
M1
M30
