Hello everyone,
I'm resurrecting some old equipment that has not been used for >5 years.
A linear actuator with what looks like a worm gear system and guiding rails.
It 90% working, but has some trouble during a small portion of the travel...about where you see the grease buildup on the worm. Also an another section it does a little short skip.
Any recommendations how to re-grease/clean this thing. What grease to use? Should I remove the buildup?
Specs:
speed, up to 2 cm/s
travel: 40cm
weight capacity: ~500lb
Thanks in advance.
P.S. Happy to read any source material...like Machinist Handbooks etc.
Specs:
speed, up to 2 cm/s
travel: 40cm
Thanks in advance.
