Hi atomicjoe:
I'm not sure you can make the economics work out compared to molding; the energy use to make a single printed part is high compared to molding, the material is expensive compared to molding resins, the maintenance of the equipment is expensive compared to molding and the time required per part is very high compared to molding.
However if you're talking about a continuously evolving set of parts that would require costly continuous fabrication of new tooling, you'd have a good candidate process with 3D printing provided you can get the physical properties you need from a printed part; unfortunately, TPE's are likely to be pretty challenging in that regard.
I don't think you can get the molecular crosslinking you need to get a truly elastic part from laser sintering, and you'd likely have to accept compromises in other physical properties like UV stability, tear strength, colour stability and on and on.
Have you considered working over your current processes to make them better?
For example, if you're finding a significant cost burden with mold repair, can you commission better quality molds?
Can you standardize your mold bases and clamp systems, cooling hookups etc etc to make them go faster?
Can you accept carrying bigger inventories of popular parts so you don't waste money on having everything JIT?
For the cost of bringing a 3D printing process on line and validating the process to your part requirements, you can do an awful lot to optimize what you already have.
If you're looking at a budget of a quarter million or so, you could justify a massive inventory of conventionally molded parts, and you'd know exactly what you have made.
I'd consider 3D printing only if the following criteria can be met:
1) modest physical property requirements; no big stretches, no high cycling rate, no harsh environment, no stringent cosmetic criteria etc etc.
2) relatively complex parts which would take expensive tooling to make
3) low total volumes (under a couple of hundred parts or so??) and fast part obsolescence
4) no aggressive production schedule
Geez, I sound like a real 3D printing hater; I'm really not, but this application doesn't sound like a great fit to me, even though I know very little about what you're trying to do.
So don't take what I'm saying as gold plated and incontrovertible; I may be way off base (but I don't think I am
Cheers
Marcus
Implant Mechanix – Design & Innovation - home
www.vancouverwireedm.com
Another thought: I just browsed a web page for the new Arburg Freeformer that's coming out soon.
It's a glorified 3D printer but among its claims to fame is that it can run TPE's,and uses the same granulated feedstock that a conventional molding press uses.
It deposits droplets rather than a filament; the resolution is comparable to an FDM printer, and it is intended to be a production machine for low volumes.
It's worth a closer look I think, even though it suffers from many of the basic shortcomings of any other 3D printing process.
No definitive pricing information but apparently the gossips say somewhere in the 100K range.
MC
