...another ad showing the lower spindle set up for use...
...a couple of photos of the McCabe at Railtown 1897...
...a really great photo of two young men using a McCabe that appeared on this forum almost eight years ago from member "weber"...he being the young man on the tailstock...this is the future Cass Railroad lathe...at the time in the shop of Paul Weber...
Recent reporting on McCabe on the vintagemachinery site
J. J. McCabe Lathe & Machinery Corp. - History | VintageMachinery.org
also suggest that McCabe was not the maker and suggests another well known old firm for this role.
lathefan:
Your picture in post#1 is of the improved "Heavy Duty" model introduced in the Spring of 1902. The main improvements were an increase
in swing from 44 inches to 48 inches, moving the "Back Gear" from the back of the lathe to the front of the lathe and an increase in
weight. Shortly after this time, a "Raised Swing" model was introduced that features a swing of 32 inches on the lower spindle and 54 inches on the upper spindle. By 1905. the factory supplied a motor driven model in both AC and DC motors.
The picture labelled as 1897 is a bit misleading as that style of faceplate was not available until a much later date. Referring to
the pre-1902 ad, you will notice that three faceplates were sold with the lathe. A small one, a large plain one and a large geared
one. It would seem that after the 1902 improved model was introduced only the small faceplate and the large geared faceplate came with the lathe, but the large plain faceplate was available on request. The design of the geared faceplates changed a bit over the years,
with respect to the number of slots, both "T" and plain. The large geared faceplate with the hole in it was the result of complaints
from users about the fact that it was a bit awkward to change from the large faceplate to the small faceplate or chuck on the lower
spindle for turning light work. When the large faceplate had to be remove, it was necessary to insert a "tommy bar" into a hole in the
upper spindle and unscrew it while the faceplate was kept from moving by locking the lower spindle. To remedy this problem, a large
hole was cut in the faceplate to allow the driving pinion to be unscrew and removed. then a bushing and an extension spindle could be
installed through the hole and the small faceplate or a chuck could be installed. The large faceplate remained installed and since the
driving pinion had been removed and the drive gears to the upper spindle disengaged, the lower spindle was ready for use. Compared to
removing the large faceplate, this was a very fast and convenient way of setting up the lower spindle for small work, but keeping the
upper spindle ready for the big jobs. The upper spindle is a solid 4-1/2 inch shaft with a large bearing surface.
Originally, the lathes were manufactured by the American Ordnance Company, Bridgeport, Connecticut. At a later date in became the
American and British Manufacturing Company, but I don't have any information on when the change took place. It may have occurred when
Charles Churchill and Company became the British Selling Agents for J.J.McCabe, but that is only a guess.
Hendeyman
That'd cause some debate on here regarding headstock and tailstock alignment !
Regards Tyrone.
Notice
