You always bolt them down.Nice! I have a question for radial drill users. How far off the centerline of the base can radial drills can be swung without tipping over? I suppose they can go in any position if bolted down, but what about if not?
Thanks folks for your replies. Makes good sense to bolt them down. I was wondering if they were designed to be able to swing off the base by some amount, but apparently not.
Mine's not bolted down yet, but will be when the new layout is complete. We only drill above the base for our work. As a safety check I swung the arm to 90 degrees, wound the head to the end of the ram, and got my biggest guy to pull down on the end. Did not look like tipping.Nice! I have a question for radial drill users. How far off the centerline of the base can radial drills can be swung without tipping over? I suppose they can go in any position if bolted down, but what about if not?
On the other hand, at a shop up the road, a larger machine (not bolted down) was put in the same configuration and tipped unexpectedly. Was not bolted down and the operator did not know. So in answer to the question some tip, and some don't. But as mentioned by other posters, you should never drill off the base without bolting down, cutting forces trump gravity.
Not be under it. Based on the design and mass of the machine and some simple calcs we knew tipping was very unlikely, we just had to be sure.What were you planning to do if the drill fell over ? Sounds like Russian Roulette without the gun.
Regards Tyrone
As I said is is about to be moved to a new location and bolted down. The bolts are there ready.
I'll admit I don't know what a jet brake is. The spindle stops quickly rather than winding down, is the what you mean?
Notice
