borne2fly
Hot Rolled
- Feb 7, 2008
- California
13" Leblond roundhead (1947). Seems a lot like a manual transmission in there, so I have to wonder if regular 80W/90 tranny oil will work?
John,
I have to ask ..... what is the difference? Does ISO 46 or 68 mean 46w or 68w? I'm wondering what the relative viscosity difference is.
-Don
I have always wondered why a heavy tranny oil can work so well in a transmission but it is not recommended at all in a lathe headstock. Both are gearboxes, right? Again, just curious. Will the tranny oil cause the headstock to leak? What would happen?
After all that, I can see there are good reasons for not using motor oil, especially the detergent stuff. But gear oil is a totally different animal, and no one seems to go into much depth as to why it shouldn't be used. I don't think it is a detergent oil (correct me if I'm wrong), and I don't think it's especially prone to collecting moisture. Most people leave it in transmissions and differentials for decades with no ill effects, and ISO 68 seems comparable to SAE 80W. What am I missing here?
But gear oil is a totally different animal, and no one seems to go into much depth as to why it shouldn't be used. Most people leave it in transmissions and differentials for decades with no ill effects, and ISO 68 seems comparable to SAE 80W. What am I missing here?
1. Many, if not most, of the major oil companies' "way oil" technical data sheets -- including Shell's data sheets for their Tonna oils, Exxon/Mobil's data sheets for their Vactra oils, and Chevron-Texaco's data sheets for their Vistac oils -- note that those products are generally appropriate for moderately loaded enclosed gears, plain bearings, and rolling-element bearings.
2. The "gear oils" traditionally used in automotive stick-shift transmissions and rear ends often contain Extreme Pressure (EP) additives based on chlorine, sulfur, and/or phosphorus compounds that will chemically attack copper and copper alloys, including brass and bronze. Using such an oil in a gearbox containing copper-alloy parts will, over time, absolutely destroy those parts.
Combining that fact with the fact that the material properties of copper-bearing alloys make them well suited to internal use in gearboxes -- bushings, sliding bearings, and worm wheels are commonly made of bronze -- provides the foundation for the general prohibition on using "gear oil" in gearboxes.
John
Notice
