I do not have 3PH yet nor a rotary converter. you can hook up 220 and see if the control and table work is this true? anyone have any insight for me? -John
Yes, you can.
Manuals are available by free download from Heidenhain. The manuals you need are the Operating Manual for Heidenhain TNC 151b, which is also the programming manual, and Mounting Instructions and Interface Circuit-Machine for the Heidenhain TNC 151B Contouring control, which has the list of parameters and explanations for each one.
Look in the wiring box on the side of the machine and find the 2 input terminals that feed the servo amplifiers. Hook those up to 220 single phase (while paying attention to voltage limits) and turn it on. Check the way lube level in the one shot lube and make sure the e-stop buttons are open. (Twist counterclockwise and allow them to pop out. If they don't pop out, they're already out.) They're all in the same control loop so the error message for all 3 is the same.
Once the correct voltage is applied at the terminals, operate the one-shot lube (maybe a couple times) turn the power switch on and wait for the screen to power up. The control will perform a memory check, and if the parameters are still present, a power interrupted error message. Press the CE switch (for Clear Error or Clear Entry) to clear the power interrupted error, then the yellow servoamp on switch. You should hear the sound of a relay engaging, then three lines on the monitor should show. Pass over Z axis reference, pass over Y axis reference, pass over x axis reference. Keep pressing the green button till all three axes are homed, then you can switch modes to program/edit, manual operation, dry run, etc.
If your parameters are gone, you won't get this far. It'll tell you if that's the case, and it'll also tell you if the batteries that maintain the parameters when the power is off are low. Anyway, check back here when you've got as far as you can get, then you can learn how to save your parameters. Very important.
Did you get any manuals or parameter list with the machine? Tooling?
Great machine, BTW.
Neil
