imported_brian_m
Cast Iron
- Jun 25, 2006
- Oregon
This is beating up on an old subject a little but the Autodesk F360 on-line server has been unreliable since early this morning. I eventually found out about the server problems because I went to the F360 website but there appears to be no other way of finding out about problems like this unless you visit the website to check. Is it not possible to bring up a warning on the screen that people will see at log-on? You may not see it immediately but eventually, unless the server is totally failed (not the case this time) it should appear.
I figured that I could get some useful time on the project off-line regardless.
During the day I have been having problems with Fusion 360 but frankly I can't tell whether this is due to the on-line connection or some other feature of the program since it does tend to crash fairly often under normal circumstances if you do anything that is too complicated. The problems I am having seem to be due to my design work but who knows since I really do not understand which parts of the total F360 routine take place over the internet and which take place in my computer.
If the problems I am experiencing are due to the Autodesk server then it's my fault that I decided to try to get some work done knowing about the server problems. On the other hand, if a company (and now we see this on-line service being offered by an increasing number of providers) can't keep the on-line portion working how are machine shops going to get any work done? We know the companies can't control the internet connection which is bad enough but if they can't keep their own servers systems working then what is the point of going on-line - it can only ruin their reputation.
Grumble, grumble, grump.
