DMF_TomB
- Dec 13, 2008
- Rochester, NY, USA
had a .129 hss drill broke about 1.5" deep into cast iron (casting weighs 1 ton). so i start with 1/8 carbide endmill but end up using 3/16 carbide endmill to drill it out
get about .25 deep with each 3/16 endmill til the broke drill pieces jam and end mill breaks. so i get about 1.2 deep using 5 each 3/16 end mills after 4 hours (ran out of end mills). i put in request to ok bigger hole and or screw plug hole
programmer says wasting time and money on end mills. just drill out with .453 carbide drill and will end up putting 1/2-20 screw plug in to plug hole and drill it out as programmed. i was concerned .453 carbide drill if broken is really expensive $200 to $300 and 3/16 endmills about $15 each
so .453 drill does drill out another .25 depth right through broke .129 hss drill literally in 5 minutes, of course .453 drill tip badly damage and needs resharpening
i go to tool crib and had gotten .201 die drills made for drilling hard metal, carbide tipped straight flute with rake and clearance made for hard steel and these cost about $15 each too. i show these to programmer and explain better for drilling hard metal. but programmer mad i wasted money buying from tool crib. i really thought $60 in small die drills better than risking $300 big carbide drill. so far between die drills and 3/16 end mills i had about $160 into drilling out the broke drill bit
so was programmer right using big carbide drill and drill out in 10 minutes or use many smaller end mills or drill bits and take over 4 hours ? seems like he was correct. not my first choice to use .453 expensive carbide drill made for soft cast iron to drill out a .129 broken hss drill bit 1.5" deep.
learn something new every day. programmer not always correct but in this case seems like he had the better solution. anybody else drill out broke hss drills bits ? you use small or big diameter drill ? programmer said big carbide drill can better take little broken drill bit pieces moving and getting jammed in hole without breaking. sure tip badly damaged and need resharpening but big .453 drill did not break
