This alarm refers to the DRS, pin 6, of the control being in a logic "0" state. The configuration of the cable for Xon Xoff Handshaking should be as follows:
Machine End -------------------------- PC End
Male DB25 connector ---------------- DB9 Female
1 -- Cable Shield ------------------- Not connected
2 --------------------------------------- 2
3 --------------------------------------- 3
| Bridged
5
7 --------------------------------------- 5
6
8 All Bridged
20
This configuration is referred to as a Loop Back, Null Modem cable, and gives the illusion of Full Handshaking, when in fact there is no handshaking at all. In a Hardware Handshaking configuration, pins 6 and 8 are bridged and then connected to pin 4 (DTR) of the DB9 connector at the PC end. The loop back comes comes about by connecting pins 6 and 8 at the control end to the DTR pin (20) at the control end. As your problem seemed to happen suddenly, its likely that you have a hardware problem with the control. After checking the cable configuration is correct, use a multi-metre to measure the voltage across pins 20 and 7 at the control; it should be around 12VDC, but anything between +4VDC and +24VDC will work.
If you find less than 4VDC with the above test, a work around if you don't want to spend any money, is to bridge pins 6 and 8 at the control end of the cable, and then connect them to pin 4 of the DB9 connector at the PC end.
Regards,
Bill
