mh454
- Jul 13, 2003
- North Dakota
Hello everyone! I'm working on a new production machining project and looking for some advice. Though I've worked with aluminum for years, this is my first large scale project. We are looking at 4,000 hours of machining a year over 4 years. At this point I'm getting heady to start programming and looking for tooling.
Machine and setup:
Horizontal 4 axis 50 taper with 500mm pallet
30 HP 15,000 RPM max (though we usually don't run past 13,000 RPM)
Older Fanuc 15M controller (1993?)
Machine is capable of high feeds but not the best at turning directions very fast or processing ramping code.
Custom made fixturing on 500lb tombstone. Fixturing should be quite rigid with large serrated edge clamps pushing stock into serrated square grippers.
Roughing tools will be in hydrolic tool holders
Has very good flood coolant and through the spindle coolant
Part:
Starting stock size is 25"x16"x2"
7075 or 7050 (haven't confirmed which yet)
Approximately 85% weight reduction so lots of pocketing
All larger pockets are about 1.55" deep with .090 corner radius and .26 inside radius
I'm leaning toward a 3/4" for roughing and will have to use a 1/2" for finishing because of the .26 inside pocket radius. I plan on drilling a plunging location before roughing as I don't want to ramp in with the rougher. Ramping eats a lot of code and the controller doesn't have much memory.
I've looked at OSG, Fraisa, Benchmark, and just recently looked at Data Flute (which I've never worked with). I'm pretty set on using a rougher with a .090 corner radius simply to reduce the material the finisher would have to remove (a smaller radius would force me to leave step in the corners for the finisher to remove which would mean more "Z" steps and more code. I notice that most of the endmill manufacturers are offering "hog" style roughing endmills with chipbreakers. I've never used this style of endmill before in aluminum and looking for some opinions on them. Basically I'm looking for others who work with roughing large amounts of aluminum and what they have found works and what doesn't work. Thanks!
Machine and setup:
Part:
