I have a 1905 patent drawing that describes 2 parts similar to a pulley.
I do not have dimensions,but i do have a drawing,was hoping someone could look at the drawing and read the description to mill the parts.
If the initial set of wheels work, then i will need larger sets made.
. The Diameter of the wheel is approx 10 to 12 inches,
. the inside profile (?) (Like where the belt would go ) is a half circle
. the inside profile needs to be without blemish or nicks.
. 1 wheel is slightly wider then the other
. 1 wheel is slightly larger in diameter then the other.
These wheels will be used to form molten glass into spheres.
Thanks in advance
Thanks in advance
