Hebrewhammer8
Cast Iron
- May 14, 2009
- Bellingham, Wa
tech just serviced this 05 vf1 with reinshaw toolsetter and probe.
however for some reason he ran out of time/couldn't get the probe to work.
I tried the calibrate probe xy macro that came with the machine and the probe does not work however when i manually move the stylus the controll will beep so i assume that it is getting trigger info.
tried the toolsetter and the macro for that seems to do all but what its supposed to do.
i get a probe open alarm when i try the probe calibrate xy.
here is the program:
O9802(REN CAL XY OFFSET)
G103P1
#3001= 0
G04 P250
G04 P1
G04 P1
G04 P1
G04 P1
G04 P1
G04 P1
IF [ #3001 LT 200 ] GOTO999
G65P9724
IF[#7NE#0]GOTO1
#3000=91(D INPUT MISSING)
N1
#1=185
WHILE[#1LE199]DO1
#[#1]=#0
#1=#1+1
END1
#10=#5041
#12=#5042
IF[#26EQ#0]GOTO2
IF[#18NE#0]GOTO2
#18=5*#179
N2
G65P9721D#7Q#17R#18Z#26S#[#161]
IF[#199NE0]GOTO3
G0X#177
#[#161+2]=#10-#177
G65P9722D#7Q#17R#18Z#26S#[#161+1]
IF[#199NE0]GOTO3
#[#161+3]=#12-#178
GOTO5
N3
G0X#10Y#12
IF[#199EQ2]GOTO4
#3000=92(PROBE OPEN)
N4
#3000=93(PROBE FAIL)
N5
G0X#10Y#12
N999
G103
M99
not yet up to par reading maco's so can anyone lead me in the right direction why this isn't working?
G103P1
#3001= 0
G04 P250
G04 P1
G04 P1
G04 P1
G04 P1
G04 P1
G04 P1
G65P9724
IF[#7NE#0]GOTO1
N1
#1=185
WHILE[#1LE199]DO1
#[#1]=#0
#1=#1+1
END1
#10=#5041
#12=#5042
IF[#26EQ#0]GOTO2
IF[#18NE#0]GOTO2
#18=5*#179
N2
IF[#199NE0]GOTO3
G0X#177
#[#161+2]=#10-#177
IF[#199NE0]GOTO3
#[#161+3]=#12-#178
GOTO5
N3
G0X#10Y#12
IF[#199EQ2]GOTO4
N4
N5
G0X#10Y#12
N999
G103
M99
