dsergison
- Oct 23, 2003
- East Peoria, IL, USA
Thanks to all who sugested this. It removes material at about 2x the rate of plain Z axis sinking.
It uses a piece of tubing threaded on the end to accept graphite buttons. (or flushed copper rods of whatever size) A foam earplug seals the tube behind the er16 collet, It has a cathead adjustment (4 screws on top bearing bore insert which is oversize and and the lower insert is a cone) to set eccentricity. it is powered by a bar-b-que rotissery and some small chain I had on hand.it turns about 10 rpm. the rotary union is brass, orings, and UHMW scrap. The slip ring is a spring loaded graphite button on top. It's fed a little lube through the screw thread, keeping it just moist.
The parts I've been getting in to burn are to tall to fit under my gromax orbiter + the needed tool travel, so I build this rotator to hang past the side of my ram.
