I have read several threads about media blasting and grounding and I can't seem to stop getting shocked. We have a good Empire blast cabinet we use for glass beading aluminum. I have a grounding wire going from the gun to the cabinet. I have a wire grounding the work piece to the cabinet. I have a wire grounding me to the cabinet. That same wire goes from the cabinet to an 8 ft. grounding rod. The cabinet is also grounded to the steel building.
A severe part of the problem probably lies in the set up inside the cabinet. The cabinet walls are lined with adhesive backed plastic sheet and the floor has a piece of plastic mesh because the part being blasted cannot be scratched and it is pretty heavy. The plastic is supposed to be some sort of static dissapative sheet from McMaster. My thought was initially that this plastic is keeping the part from being grounded and building up a good charge itself, which is why I added the wire from the piece to the cabinet. I also have bare wires that lay across the face of the plastic sheet and then to screws in the cabinet. I did this thinking the plastic sheet was building up a charge that was not being grounded through the adhesive. I just finished blasting a piece and when I reached for it got a massive shock that I could feel leave me through the grounding wire I wear connecting me to the cabinet. I think the charge entered me through the glove which is a regular heavy rubber glove like most cabinets have.
So I think my question is, am I grounding things correctly? Also, is there a better solution for the inside of the cabinet to prevent the work piece from being scratched but also maintain a good ground?
I hope this makes sense. Thanks for any help you can offer.
