jscpm
Titanium
- May 4, 2010
- Cambridge, MA
I am looking at a design for a specialized kind of shaper that essentially shaves a piece of material and I want to design the machine to make the cleanest cut possible (no shearing). My main concern is how to determine the optimal speed of the cutter to make the cleanest possible cut. This device is not a production machine, but would only be used in a laboratory setting where the cuts would be made periodically. The thickness of material removed will be very thin, maybe 0.001" or less at a time, so we are just shaving a thin skin off the top of the work piece. (Obviously, once the thickness being shaved goes below 0.001" the machine is turning into a high-precision device, so an ordinary shaper cannot be used.) The behavior is similar to that of a microtome, but microtomes are designed to cut biological tissue which is much softer than the materials I need to cut.
The most common type of material that would be cut would be a polyimide resin, which is basically a kind of hard plastic.
The simplest possible design would just have the material in a holder and the holder would be driven against a fixed blade using a screw. This would produce a slow steady force.
In a traditional shaper the blade is driven by a flywheel. The cutter motion in such case would have a quadratic variation in the speed of the cutter, but of course, the machine can be designed so that the work is only contacted by the blade over a short range of its motion, so that the speed of the cutter would be somewhat constant while it is cutting.
My problem is: how do I determine the optimal speed of the cutter? Do I use a screw and just cut through the material really slowly, or do I have the cutter slam into the work at high speed? What will produce the cleanest cut?
Also, if we consider the way that the cut occurs, the blade encounters the material and the material resists, so the force builds up and the material will tend to compress, but then the cutter breaks through and cuts easily after that. So, there is an initial shock when the cutter first hits the workpiece, but then much less resistance as the cutter continues through the material. How do I design the motion of the cutter in such a way that optimizes for this kind of action?
I am looking at the way microtomes are designed (which tend to be idiosyncratic proprietary designs), but since the material they are cutting is extremely soft, it is only partially relevant.
