dale71
- Nov 13, 2006
- indiana USA
Will a carbide drill drill through a piece of air hardening steel that was hardened to a Rockwell hardness of that of a drill bushing? Or will it have to be edm'd?
Ditto, All I buy are straight flute carbide drills. I have even used them to drill out the center web of broken taps. I would recommend alternating between coolant and air blast to get the chips outA straight flute carbide drill as shown above would be best for drilling out bushings.
I have used resharpened masonry drills with a negative rake for non serious holes,such as drilling holes through large HSS hacksaw blades to make rivet holes for knife handles. Or,for drilling through a file to attach a wooden handle on 1 side for filing guitar frets. Masonry drills work for these type jobs. However,their brazed tips can get too hot,and let go. Also,for drilling through HSS power hacksaw blades,I have found it necessary to resharpen the tip for each hole,or the drill pops the hacksaw blade in two.
Those were the non critical jobs I have done with masonry drills,Dave,and they work fine for that. So,if your little face was for me,take it elsewhere.
Notice
