cbellamore
- Nov 22, 2010
- NY
I recently upgraded my Logan 922 lathe with a quick change tool post setup and went with some 1/2" indexable turning holders
I am looking to stock up on some inserts
the ones that came with my holders have the following specs
C6 Carbide with chip breaker
TCMT 32.52
I have to be 100% honest in that I have no idea what brand or what type of inserts I should be buying or using for each material before this I was hand cutting HSS bits on a grinding stone to suit my needs
I mainly cut chromoly steel, 304 stainless steel, and aluminum on the lathe
what inserts should I use for the following ?
1. 304 Stainless Steel
2. 4130 Chromoly
3. Aluminum
4. General Cold Roll Mild Steel
I run a small motorcycle shop that specializes in vintage Harley Davidson Choppers
so everything I do is mainly small stuff where I need to face off a piece or turn down a piece and every now and then some boring and some threading work
I mainly turn lower lower fork legs to make them smooth
make up some mounting bungs
make up some wheel axles
small stuff like that
I am not a big industrial type of shop
I do spend a few hours a week on the lathe and its basically a learn as I go type deal as I never took any formal machinists school or classes (although I wish I would have)
so any recommendations on what type of inserts I should be buying would be greatly appreciated and what type I should be using for each material and any specific brands of inserts etc would be greatly appreciated
Also I dont have an unlimited budget I would like to find something that is reasonably priced as I am not doing any type of precision work etc.
This forum has been a huge help in me learning the things I have so far to operate my lathe and make up the pieces that I need
TCMT 32.52
2. 4130 Chromoly
3. Aluminum
