captf71
- Oct 18, 2008
- west jordan, utah usa
Good evening. I recently obtained and refurbished an old Orbit bench top DP. I checked the spindle runout after bearing replacement and reassembly and got "0". I then installed the chuck and it had .009" runout 1" below the chuck. I tapped it awhile and the best I could get is .007" so I thought a new chuck might be a good idea.
It has a Jacobs 33 installed currently however when I measured the spindle, the readings (.670 x .624 @ 1") are actually almost right on for for what I thought was a JT 6 so I'm perplexed as to how a Jacobs 33 fits. I don't know much about this stuff so I'm probably missing something.
The machine label indicates JT 21/2 which I interpret as a #2 Jacobs Taper with 1/2" capacity.
Is there a way to reduce the runout in the chuck without reaming or boring?
Am I out in left field with the Jacobs Taper measurements on the spindle or is there something else going on here?
Rog
Rog
