Thomas Green
- Nov 30, 2005
- Aurora, Oregon
I have a special need to roll some flat stock into a flat ring. The material is 4130 steel sheet (normalized) and it pretty darn tough. The flat form is .063" (1/16) thick by about 1 1/2" wide by about 11" long and when rolled it needs to be about 3 1/2" in diameter.
Perfection of the final rolled component is not needed.
My problem is finding something like a slip roll but one that is HEAVY duty with the narrow, tough capacity to perform this task in a commercial environment. I anticipate needing to roll about 3000 per year.
The slip roll I tried is simply too flimsy and of course way wider than necessary (36"). Also the 4130 wears into the rolls pretty fast...
Do any of you know a tough tool that will do this? Is there somehow to use a lathe for this? I have a darn big Mazak lathe but can't see a safe and reliable way to use it for this forming job. Thanks, Tom
