I need to tap the M7 holes for my exhaust studs on my head, and was just going to tap it to M8. Then I would buy bigger set screws, and be done. But, something in me kept telling me, with little room for error, just tapping to the next size is not the right thing to do. So, I went to Google and educated myself a little on screws and threads, and I think I am right. Like I said, with little room for error, I need to make sure whether my suspicions are wrong or right.
What I need to know is, when you have a hole that is tapped at M7x1, and you tap it up to the next size, M8x1.25, will the threads come out right? Even if it's just the next size up, are you always suppose to drill first?
If I am correct, if the pitch from crest to crest is 1mm, the distance from the crest (major diameter)to what would be the minor diameter, is also 1mm. So in an M7 tapped hole, it has to be drill to 6mm(minor diameter)plus the pitch 1mm (.5mm on each side of the screw) making it an M7-7mm (pitch diameter) hole. But, if what I said was correct, then you have to add another .5mm to each side, to get the major diameter. That makes this hole 8mm wide. Now, I want to tap it to accept an M8, the drill bit to use is a 6.75mm drill bit. If the hole left behind by the M7 is a total of 8mm wide, and I was to use a 6.75 drill bit to prep it for the M8 tap, there would be .75mm of threads on each side left behind by the M7 threads. That brings me back to my previous question, will the threads come out right, if you just tap to the next size? Did the creators of taps and dies predict this, and make it to the point that, if you always drill it out, the threads left behind will never matter? That they are made just right so the next size up always works, or is there some rule of thumb, where you always tap a stripped hole up 2 sizes?
I believe, if I was to use M9x1.25, it would work perfectly, but they seem to be hard to find, in 39mm set screws. The drill bit to use for the M9 is a 7.75mm bit, and that would only leave .125mm of threads behind. That little bit, cant matter much, but I don't know, that's why I'm here. Because of location, my ultimate goal is to do this right the first time, while taking the least amount of material/aluminum away. Plus, the holes on my manifold aren't that big, they may accept the M9, but I would have to drilled it out for the M10. My fear is that I will have to use the M10, because in order to get the best result, you want to remove all old threads, therefore; I would have to use a drill bit bigger than 8mm, and the M10 uses an 8.5mm bit. Also, I would like to have 1.5mm pitch threads to holed on the exhaust, but 1.25 is fine.
I can't explain how much I did not know about threads before today. I knew how to buy what I needed (match the numbers) but I didn't know what they meant. All of the terminology and numbers I just used, were from a ten minute crash course on Google images, and using a drill bit tapping chart. I believe everything I said and the math I did is correct, but if it is wrong please let me know. As much as I do, just need the answer to the questions above, I would like to know if my understanding of threads is correct.
Thank you very much for your replies.
