MonkeyDoes
- Jan 17, 2012
- michigan
Hi guys,
I am in need to take some of my prototypes into production. I believe I need to start a relationship and have a source for the tubing from one manufacturer. I would like to avoid having to tell a tube mill I am currently buying from one of their customer's. So, I would like to go to the source as soon as I can. I have designed my product so that it uses the most readily available tubing there is, so as it would be easier to add on various lengths if it doesn't meet their 5000 foot minimum.
The tubing I am using is currently, 20 to 16 gauge steel tubing. Squares, rounds and rectangles. This will be used for furniture.
I was told that generally tube mills will run lengths (if it does not meet their minimum) that they're going to run for another customer's order.
Now my question is do you guys know of any tube supplier in the southeast Michigan area? I am not afraid to go farther if needed. My next question is how do I know how much I should be paying / how much more I should be paying for smaller quantities.
My last question, is my thinking here right?
Thanks guys.
Thanks guys.
