ajk2004
- Oct 12, 2014
- Fort Dodge, IA
Good morning guys,
I have a 1960s clark c60 that I use for moving my metalworking machinery and steel around the shop. It is old but runs great and gets the job done. My brother was driving it last week and hit a bump with it and it stopped moving. When you put it in high/low forward/backward it will act like it wants to take off but just sits there. The trans fluid was low when it stopped but it is full now but having problems. There is a port on the top of the axle that I took off and when I put it in gear the big ring gear/bull gear moves like it should. Should I rule out the transmission at this point? I'm guessing I'm going to have to take the mast off and disconnect the axle assy. from the lift. Before doing that is there something else I should check? Thanks for the help.
Andy
Andy
