skydawg
- Nov 23, 2014
- Washington,NJ
I knew oil wasn`t getting to the cross slide or saddle,thought the metering units were clogged.After removing the apron,the oil pump seems to be the problem,not a trace of oil movement.I blew compressed air into the output line,still nothing.Is there anything I should check before pulling the pump?Could it need to be primed somehow? Thanks.
