CrookedRiver
- Apr 6, 2016
- Cuyahoga Falls, Ohio
Hey PM owners,
I'm starting my own shop and would very much appreciate your opinion on thrift-shop tier CNC mills.
Here's the situation: I recently became unemployed and have decided to strike out on my own. I have ten years' experience in CNC manufacturing, started as a button pusher and worked my way up to setting up/running/editing programs for a 9 axis millturn center doing military aerospace work. Got an engineering bachelor's degree and worked for two years as a manufacturing engineer for a major metal products company. No experience running a business but pretty good at designing parts and making chips. I'm relatively young and childless, wife can pay the household bills with her job so I think it's a good opportunity to take a swing at ownership. I have my own products which I wish to manufacture and sell, not interesting in job shopping. These are primarily milled parts. For turning purposes I have a Mazak QT10 lathe which I rebuilt in my spare time that is ready to go. I need to find a solution for CNC milling - I have a series 1 Bridgeport manual, but am under no illusions about my abilities as a manual machinist or ability to make parts competitively on a manual knee mill.
I bought a Bridgeport Interact Mk II off of Craigslist for a very small amount of money. The control powers on but is non-functional due to a faulty spindle motor VFD and a missing relay signal somewhere. I've spent 20+ hours crawling through the control cabinets with my multimeter but can't find the fault. Control is a Heidenhain 2500, I've run them before but not really a fan of 1980's conversational controllers. I'm not willing to put money into fixing the controller, I'm parting it out on Ebay. The mill is physically in decent shape. Ball screws look bright and new, spindle turns freely by hand with no noise or resistance, limit switches all function, ways are bright and flaked, only a little surface rust on the table and some gnarly paint. Servo motors are present on all 3 axis, condition unknown. Sometime in the late 90's this machine was retrofitted with a 10HP spindle motor and Baldor VFD.
I have the option of restoring this machine with a retrofit kit, the Centroid one offered by Ajax looks pretty good to me. About $4000 for the kit, and I'm confident in my ability to install it. However, it still has some limitations: No ATC, no enclosure, not sure how hard I want to push a 10HP spindle with 30 taper tools, and the rigidity limitations of a knee mill.
I would dearly like to have an ATC so that I can load a part, hit go, and then do something else while it runs. An enclosure would be great for mess containment; I have no objection to mopping but it's not a profitable use of my time. What I'm really looking for is a used VMC or HMC as cheaply as possible, or a functioning CNC knee mill for about the cost of the centroid retrofit. Not really considering Tormach, by the time you add ATC and enclosure you're up around $14k and are working from steppers instead of servos. How cheaply and from where can a machine like this be had? All advice appreciated.
