snowman
- Jul 31, 2004
- Southeast Michigan
Ok, precision is relative I guess. I need to build a device that can have planned linear movement (on a track) across 60 feet. True stopping position must be within 1/16 of programmed stopping point.
Speed isn't really of great concern.
Gear Racks, Chain, belt, etc. I know that it can be done with the double helical, precision rack....but I'm not sure how to spec out precision class, or even if that is really going to be of great concern as long as circular pitch is maintained between the gear teeth at rack joints.
If I'm just using a run of the mill gear rack from McMaster carr, how to I determine total possible error over 60 feet of movement? (based upon perfect theoretical alignment of pitch diameters / circular pitch of rack / etc...just the compounded tooth error)
OR
Is there a simple way of measuring linear position. Similar to a glass encoder, but just really long.
OR
