FTF Engineering
Hot Rolled
- Oct 30, 2003
- Philadelphia, PA
There have been previous discussions on gib screws working their way loose and ways to improve the situation from lock nuts, to Loctite, to Teflon tape, to monofilament fishing line. I'd been using Teflon tape on mine since reading that thread, and it works fine until you have to take the screws out:
After cleaning out all the old Teflon, I decided to fix the problem once and for all with a different approach. I cross-drilled all of my gib set-screws and inserted plastic vibration resistant plugs. Here's one of the finished products before screwing it into place:
Here's what I did. First, I made a little brass fixture to hold the setscrews for cross-drilling:
After drilling the set-screws, I turned down some Delrin that I had laying around to fit snug into the cross drilled hole:
Here's a close-up of the setscrew and the Delrin insert:
I did all the setscrews, both for the cross slide AND the compound, and it works GREAT!!! No Teflon or Loctite mess. Looks stock and no external lock nuts for chips to hang up on. I've had the screws in and out at least twice so far and they're still snug. I wish I'd done this years ago!!
What did I learn and what would I do differently?
a) The set-screws are of varying degrees of hardness. About half of them were no problem... Drilled easy and deburred with a file. Some of them, however, were very hard and I had to sharpen my drill bit a couple times just to get through it. One of them was SO hard that a file wouldn't even touch it for deburr and on that one, I had to resort to a Dremel with a cut-off wheel that I'd "dressed" into a thread profile V. If I were doing this job again, I would probably spring for a carbide drill bit. I don't know if a carbide bit would survive the interrupted cut, but I'd be willing to spend the money to find out.
b) Trying to force my way through the hardest of the screws put a lot of side load on the drill bit and started to oblong the drill guide hole. If I were doing this again, I would make the holding fixture out of steel instead of brass.
c) The drill bit guide hole ended up being right on top of a thread crest and if I were doing this again, I'd be less concerned with the absolute distance from the end of the setscrew and more concerned that the hole were in a thread valley instead of a crest. I believe trying to drill straight into the top of a thread made the side load on the drill bit worse than if it would be naturally guided into a thread valley.
I may still have a screw loose, but at least it's not on my gib!!
