mtlhe
- Aug 17, 2004
- redding,calif.,USA
Hello, nw to forum&lathes. Just bought a SB10L. It has the orig.switch that designates forward & reverse. However, reverse doesn't work. It was setup to run on 240v.Orig.wiring diagram shows a 3ph. motor.Orig.paperwork indicates this was shipped w/o a motor from SB.Q:Can a single phase motor run in reverse?If not, is this a big deal? Also, it has a leather belt which is in need of replacing. Is there any dealers that offer a never composite version that isn't difficult to install? Thank you
