QuickChange
- Jan 28, 2013
- NE Ohio, USA
Can someone recommend a trusted source for a decent quality, reasonably priced 2MT reamer? I was thinking of purchasing the reamer for use in "cleaning up" the tailstock (TS) taper on my 9" SB. I don't think the taper on the TS is holding quite as well as I would like. Over the years I have experienced a few occasions where I was drilling using the tailstock, and the drill bit subsequently "grabbed" and began spinning the drill chuck in the TS. This happened again just yesterday. I removed the drill chuck from the TS and cleaned/wiped down everything and reinserted into the TS, but the same thing occurred moments later when I resumed drilling. The interior of the TS bore looks OK, but has what I would describe as some VERY slight scoring. It is just not holding as well as I think it should. I'm thinking just a quick cleanup reaming of the TS taper will put everything right? Any and all suggestions welcome. Thanks!
