I have set up a 15hp RPC to run a powermatic vertical bandsaw, and for future equipment for my little home shop. I have a question regarding the some wiring options for the magnetic starter.
The RPC is dead simple...pony start, unbalanced. Works like a charm. Because it is oversized for the little 2hp motor on the Powermatic, I am not concerned with balancing at this time...maybe a future project. My generated leg runs about 10% lower than other two legs at idle. Haven't measured at load yet.
I am using a Allen Bradley 709 series size 0 starter...here is the wiring diagram
My question is this...using a 240v coil in the starter, am I OK to use my unbalanced generated leg(L2)for one leg of the coil circuit?
My initial thought was that it would provide protection from single phasing if something caused the RPC to drop offline or if there was any problem. But I am not sure if the lower voltage, and maybe fluctuating voltage, would be an issue for the coil? Will the coil operate at the lower voltage from my generated leg (about 217V at idle), or should I use the two factory legs at the full 240v to power the coil and give up any "single phasing" protection? Or maybe there is another method I am unaware of to provide "single phasing" protection?
Thank you in advance for reading and replys...
Chucky
Chucky
