Mark Leigh
Stainless
- Jan 8, 2008
- Merced, Calif
I am presently wiring a three phase RPC and installing a three phase panel with breakers to feed my present and future needs. The RPC is a 240 single phase input with 240 three phase output.
The leads coming out of the RPC to the three phase panel are two blacks, red and green.
Do I land the green from the output of the RPC to the ground lug that is not insulated from the panel or do I land it on the neutral bar that is insulated from the panel ?
My confusion lies in that no matter how I land it, how does the ground system work , since the panel isn't grounded to earth or the single phase sub panel right beside it ??? I keep thinking that I should be grounding the panel somehow ?
Thank you in advance, Mark
