metalmagpie
- May 22, 2006
- Seattle
I think the original post was a troll.
What makes you say that? It was absolutely not a troll but rather a genuine outreach to people in the know.I think the original post was a troll.
Why would it cost several thousand to transport a lathe that is 2 hours away? Get into truck and drive there, load, and return same day.I did find a Clausing but it's about 2 hours away from me and from what I can tell the price to get it here would be several thousand.....and the guy hasn't responded to my requests to take a look at the lathe.
Don't forget to try schools and colleges. Here in the UK they often used to have a mill and lathe. Some still do but without anyone able to teach the students how to use them. My lathe came from a girl's school and my Bridgeport from a hospital. Junk yards can also yield surprises, might be worth a look. In my time dealing in machine tools I've had two Mk1 Colchester Bantams one scrap and a good one out of junk yards and a friend had a Hardinge HLVH which he cleaned up and is back in daily use.An update: A good friend of mine overseas has offered his help with financing such a lathe. And my budget has about tripled so I can get into the 2 grand range. Does ANYONE know of a good source for used machine tools in the Philadelphia, PA area? I've tried Craigslist and Facebook Marketplace to no avail. Googled used machine tools in the area and was surprised to find so few resources. I did find a Clausing but it's about 2 hours away from me and from what I can tell the price to get it here would be several thousand.....and the guy hasn't responded to my requests to take a look at the lathe. So....Philadelphia area......used machine tools......used lathe......1.375 spindle bore.
Don't egg him on too far. I might feel the need to link the post where he complains about young people not honestly dealing.JohnK: you wrote what you did as if you are proud of it
Hello one and all.....Why would it cost several thousand to transport a lathe that is 2 hours away? Get into truck and drive
If the collet closer runs from the right hand end of the spindle all the way up to the spindle nose so it can close and open the collets, then by simple logic that would sort of indicate it has to have the typical and pretty much universal through bore. It's either that, or it's working by breaking the rules of physics. In your #26 post in this thread you mention you used to build pool cues on Clausing lathes, even retrofitted them with inverters after removing the hydraulics. Yet you seem to require help with even figuring out how to move one from point A-B as well as completely entry level questions anyone with even some limited experience should already know or can easily figure out. Normally I'd be fine with those, but my bs and not adding up detector is telling me something. So I think I'm out of what's starting to look very much like what Metalmagpie mentioned. I wish you luck.Hello one and all.....
I may have hit the jackpot. I'm in the market for an affordable lathe and I had someone reach out to me with a semi-old family lathe. It was passed down to him by his grandfather through his father. The label on the machine ID's it as a South Bend model CL670Z. I did some research but couldn't find a definitive spec on the headstock bore. I believe it's 1.375 Can anyone verify this for me? Thanks so much. I looked at the manual but I can't figure out if the bore goes all the way through the headstock but it also looks like there's a collet closer attachment that runs from the end of the headstock to the front where the collet is. Sooooo....I'm confused. Does this machine have a bore that goes all the way through?
Your mentioning the information about the collet closer is precisely why I was asking my question. Because from the photos I've seen it simply DIDN'T make sense. So.....instead of assuming.....I asked. the experts. I've never SEEN a South Bend. Never WORKED on a South Bend and I know nothing about their construction. The documentation I've found is confusing to me....big F-ing deal. So, I ask. There's a general rule of thumb I go by in life. If I don't know......I ask. Another good rule of thumb for you and whatever a MetalMagPie is would be, "If you don't have something of value to contribute then don't say anything." Man, oh man you two are crabby. Why? Nevermind. I really don't give a shit about your collective opinions of my questions or my reasons for asking them. Truth be told, my motives, for lack of a better word, are really none of YOUR (plural) business. Always remember and never forget.........be nice.If the collet closer runs from the right hand end of the spindle all the way up to the spindle nose so it can close and open the collets, then by simple logic that would sort of indicate it has to have the typical and pretty much universal through bore. It's either that, or it's working by breaking the rules of physics. In your #26 post in this thread you mention you used to build pool cues on Clausing lathes, even retrofitted them with inverters after removing the hydraulics. Yet you seem to require help with even figuring out how to move one from point A-B as well as completely entry level questions anyone with even some limited experience should already know or can easily figure out. Normally I'd be fine with those, but my bs and not adding up detector is telling me something. So I think I'm out of what's starting to look very much like what Metalmagpie mentioned. I wish you luck.
Notice
