ENGINENUT2
- Jul 13, 2005
- Dickson, Tennessee USA
Toolbert, You can find a lot of Kohler specs and tolerances at: http://www.yetmans.mb.ca/kohler/-----notice the M series engines specs are nearly all the same as the k series.The M stands for magnum and I think has some subtile upgrades that improved reliablity.Many aftermarket catalogs list parts the same for both.As to the gov-usually it doesn't need repair before the 2 nd rebuild unless someone overrode it severely.Adjustment is simple and just like most other flyweight gov on 1 lungers--the manual covers it well.The balancer weights must be timed at the time of crankshaft installation and there are reference marks jus difficult to see---just a little extra care.But not to worry, most of them had no balancer weights.I've seen them on 12 hp (k301) on cub cadet and Gravely shows them in the book but I never heard of a 10 hp with balancer.If you look at the shorter stroke on 10 hp (12/14/16) is the same, probably it wasn't needed for smoothness improvement.My 12 hp k 301 on Gravely was worn beyond the .040 available (.030) from Kohler so I opened it up .125 to std. k 321 size and man the difference is evident even though it lacks the larger ports and valves of the K 321--21 cu in added never hurts a thing.
