Bakerprecision
- Aug 20, 2022
Hello All,
I have searched high and low for an answer to my question with no luck. I'm trying to find the length value of my Haimer 3d Sensor in a CAT40 tool holder (Haas TM-1). I know that a lot of measurements are taken from the spindle nose, some are taken from the bottom of the taper on the CAT40. I've measured from the bottom of the taper flange to the tip of the Haimer (reading 0), and I have a pretty accurate measurement, but my issue is that I'm not quite sure where my measurement reference should be? Does this OAL need to be taken from the spindle nose, or can I use the measurement I took originally? The reason I ask (or the reason I'm confused), is because there is quite a difference between the two measuring points. Any insight/input is greatly appreciated as I cannot find information specific to Haas and the point of origin from which to measure.
