Hi everyone,
Want to preface this question by stating I am not a machinist. I am a commercial photographer as well as a woodworker, so I have tools but none that are specific to machining metal.
I have a custom cut piece of 1/4" thick 6061 aluminum plate with a series of small holes (sized for a 1/4-20 tap) cut into it that will be utilized as a laptop plate for photography.
I have a basic tap set, and have started tapping the holes using the tap in a cordless drill. There are 100+ holes needing to be tapped so a drill is more efficient than a hand tap. The tap leaves a small burr on the front and back side of the aluminum plate.
What is the best way to remove this burr. I can hand file them down but that takes too long. I tried using a 5 sided countersink, the kind used in woodworking, but that didnt work. Any ideas would be greatly appreciated!
