Is your saddle locked?
Joe
yeap, saddle always tightly locked
Joe
I've never actually run a lathe with a bent spindle, but it seems logical to me that you cannot face a flat plane with a bent spindle. This is because of precession of the axis. To face a plane, there must be a fixed axis for that plane to rotate on.
You are right, this is the detective work...if pressure from the TS solves it, my thurst bearings need some attention.
Hi Monarchist,
thanks for the reply.
show it worse towards lower-RPM center of the work than at outer periphery".
Thanos
see this....that means the problem is the bearing and the force the tool has and the depth of feed and the speed.....so if you want it flat...you have to maybe double the speed and cut the feed in half since the tool is lifting up and then releasing and dropping down and as it gets more SFPM on the outside it gets better....so and I am guessing as to speed and feed but try this....1200 RPMs and .0015 per rev....that should come out within .0005 ...if not...another trick to eliminate this is to feed in to center and then feed out to large diameter and off part....then see how flat...the radius on yer tool can be too big also causeing this...good luck...let us know if it helped ya
PERHAPS the axial runout you measured on the spindle shoulder. Means spindle is bent. Bent spindle, as long as bearings rotate true, should not cause the problem you observe.
BUT if the thrust bearing face on your spindle is near the nose, perhaps it has axial wobble, too, from the bend.
But wobbly thrust face on spindle, as long as its counterface in the bearing is flat, will have reduced thrust capacity, but will not make the spindle hop axially.
BUT if this lathe has a plain bearing, and when the spindle was bent the thrust face indented the bearing, THEN you have an axial face-cam, pushing spindle in and out.
Too many "IF"'s, but worth eliminating. I vote for hard spot in your cast iron.
a while back you said you were going to replace the spindle bearings.
What were they and what did you replace them with?
Here is the video of the runout on the face after the thrust bearing adjustment
Notice
