2SMperformance
- May 16, 2022
I recently purchased a 2007 Sharp SV2412 vertical mill back in spring and had it delivered to my house, I had to unbolt the Z axis drive servo motor and unclamp the coupling to get it to fit under my garage door opening.
I wired up my phase converter and everything works great on the mill except the 10 tool umbrela tool changer will not perform a tool change when I command it to. I enter “T2 M06;” insert and cycle start but nothing happens.
The cycle start button stays green and the green light on the top of the machine flashes until I hit the reset button on the controller.
Here is a video for a good visual reference:
The spindle doesnt attempt to rapid to tool change position on Z and the controller doesn’t seem to be running the macro program for the tool change.
I checked the program directory and the tool change program is there as O9001.
I replaced the batteries and performed the procedure to reset my axis home 0 reference positions using parameter 1815 but that hasn’t helped the tool change issue.
The tool changer still orients through all 10 tool places when I zero return all axis’ home and I can jog it around, but it will not slide over towards the spindle. My spindle also orients with M19 just fine. Im also getting good air pressure l.
Does anyone know what this problem could be? I know it worked before I bought the mill. I am losing time and money dealing with this. Do I need to manually reset the tool change position? Would love to hear some suggestions and get the issue resolved.
