michiganbuck
- Jun 28, 2012
- Mt Clemens, Michigan 48035
I've a feeling you are right dian, ..............and IMHO should have been drawn up so from the start.
Might be a threaded nose piece welded or glued in place.
Hi Limy Sami:
Did you factor in the amount of stickout for the boring tool and how skinny it has to be to reach the small end without crashing into the sidewall of the parallel part of the bore.
It's not looking promising.
Cheers
Marcus
Implant Mechanix • Design & Innovation > HOME
Vancouver Wire EDM -- Wire EDM Machining
Forged, possibly deep drawn. Think high pressure oxygen bottle. Looks like WMD.
Can't believe it wasn't noticed until the second page.
It's shockingly obvious what it is.
there ya go - somebody else for your Mr Trump to p[ick a fight with.
So unless India's [...] still in the stone age, I'm having a hard time believing the Indian Army's [...] stupidity of such a process plan boggles the mind.
HI, ALL, Thanks for your valuable inputs.
And for some of you who think it is a WMD, To assure you, it is not. This is for an R&D project for a company called as BHEL (Google for more info). The purpose and other things can't be told.. (signed an NDA).
So, now, the machining part, I am planning to use a cutter which will have 3 cutting edges with profile as per drawing. The Cutter specs are "REPLACEABLE INSERT CUTTER" with OD 135 X 900 WL X MT-5
So, let me know this thing works.
And, for anyone else who still have some ordinance related doubts, I would let you know that those things are only done by companies such as TATA, RELIANCE, GODREJ and some other multi-million dollar companies.
Thanks & Regards
bhargav
That is going to be a right bastard to machine in one piece. Saw this earlier and didn't reply, but was thinking "should have been forged." Two piece weldment would be easier too. Getting that done with a form cutter all the way down the hole is going to be a pain... The boring bar is a no-go IMO. WAY too much stickout, especially working so far down a hole it will be impossible to see what's going on. That would be about like trying to bore it with a wet noodle. If forging or welding are off the table, the form tool is about the only way I can think of that might stand a chance.
... a company called as BHEL ... (signed an NDA).
bhargav
Hi cndu:
This is going to be very hard to form turn; you have a huge surface area to accommodate and a surface finish requirement that will be hard to achieve without excellent chip control.
You have to form ream a depth of 235 mm and the torque on any form reamer will be huge.
Also you have to find a way to rough the shape first, so you can take the minimum necessary with the reamer.
If you try to single point bore it you are reaching in a diameter to depth ratio of almost 10:1 once you take into account that you cannot have a boring bar that's more than half the bore diameter (to give clearance at the back side of the bar when you're roughing the smallest diameters right at the tip of the form.)
So the only realistic way forward on a lathe is to step drill the shape as close as you dare to go, and then make a reamer with interrupted flutes (to break up the cut as much as possible) and feed it in very gently in a manner similar to how a chamber is reamed for a rifle barrel.
To guide the form reamer first you need to bore the straight section accurately to 135mm (5.314") diameter and 655 mm (25.78") deep.
That's already quite a challenge unless you have a really stout lathe with a nice rigid De-Vi or equivalent boring bar
Ideally you will have high pressure oil coolant through the tool and a big escape channel for the chips otherwise you'll destroy the finish inside the bore from chips dragging.
These will be slow to form ream and you are going to need a very powerful lathe...I think 50 horsepower is a nice number, but I haven't done any calculations so that's just a guess.
Alternatively you can find someone with a really big sinker EDM...this would be an easy job for a vendor with the right equipment.
On a last note; the easy way to guarantee the volume is correct, is to make everything a bit deeper, fill it with water, measure your difference from the water level to the open end of the bore and then turn it down to the correct length.
Cheers
Marcus
Notice
