precision tools
- Jan 19, 2005
- Toledo, OH
The method described by James Keefer is used for the best jobs. A close fitting liner in a reamed barrel using one of the Loc Tite products will produce an excellent fit. There are a couple of Loc Tite products that will handle larger clearances, but most require a rather close fit. Look through their site for the required clearances.
Probably the second best method is using an epoxy to retain the liner. Epoxy will allow lining a barrel with larger clearances. Accraglass is a good product, but the kits are expensive, and for barrel liners most epoxies will work equally as well as the Accraglass resin. I use JB Weld, it is good to 600*F and will withstand hot bluing. There are coloring agents that can be added to epoxies, black is readily available and a few drops in the mix will make it invisible.
In the days before Loc Tite and epoxies, liners were soft soldered in place. It requires care in cleaning and tinning of the liner and barrel and maintaning both pieces at soldering temperatures while installing the liner. I have done this on a pistol barrel and certainly would not recommend it since much simpler and better methods are now available.
I have never heard of either silver soldering or heat shrinking barrel liners in. Silver solder would require heating both parts to red heat and maintaining that temperature while installing the liner. This is a sure way to induce stresses in the finished product if you managed to accomplish it.
Similarly, expecting to gain enough expansion with the small diameters involved places shrinking a barrel liner in place is well outside of the normal shop abilities. It might be employed with artillery pieces, but I see no way it would work with a rifle or pistol barrel. I have never seen it recommended in any gunsmithing book I have ever read.
