sandiapaul
Titanium
- Mar 19, 2004
- Princeton, NJ USA
This machine is brand new to me, the Z is stuck all the way up and it has a No. 11 alarm.
I have the manual and it states:
"Firstly, switch on the 2nd LS remove switch on the control panel, and confirm that LED above the switch is "on". Secondly, turn the mode select switch handle to magnification 1 or 10. The axis doesn't move under the mode except them. With using handle, move the axis on the stroke end to the center of the machine for making it further from the 2nd LS."
I assume that the "handle" that they refer to is simply the toggle switch itself?
When I do as it states I can hear a click like a relay but there is no movement.
I have not run the machine at all yet, just getting started with jog, ref 0, etc when the + and not the - got pushed.
Thanks for any help!
