pMetal
- Jul 14, 2014
- United States
A flashing "MS" on a Yasnac i80 means that you have not warmed up the spindle sufficiently for the RPM that you have commanded.
On my Kitamura Mycenter 1, if I command a spindle speed greater than 10,000 RPM (or maybe it is greater or equal to 10,000 RPM - not sure), it requires that I warm it up at a speed greater than 5,000 RPM for at least 10 minutes. The machine has a timer for this which must be satisfied: If you short the 10 minutes by even 1 second, you will have to do it over again.
This is in addition to your regular 25% of maximum spindle speed for 30 minutes daily warmup.
So basically, if your program is all below 10,000 RPM, you can just do your regular warmup. However, if you have operations that are greater than 10,000 RPM, you must do an additional warmup of greater than 5,000 RPM for 10 minutes, otherwise your control will hang with a flashing "MS" once you get to the high spindle speed section.
I generally do this warmup at 5050 rpm.
Also keep in mind that if you turn your machine off and back on again (for example to recover from an E-stop), you will have to do the 10 minute warmup again to satisfy its timer.
