matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
Couple of updates: first, and most important the poison ivy was apparently mis-identified as poison maple-root, only known to affect certain species of badger and I have no ill effects.
Took out the trans dipstick and the fluid smells like, well, trans fluid. It is not dark or discolored. The Turbo 400 is one tough cookie
Further investigation shows that a vacuum line that's hooked up to the trans is quite close (too close) to the exhaust downpipe and got fried....but I can fix that rather easily.
I also have lots of oil leakage from the rear oil pan (identified when I first got the truck in Dec), possibly the rear main, although the torque converter exterior is dry as a bone. It's possible that with all the oil at the back end of the pan with the truck pointed up the hill, some oil got dripped or slung on the downpipe as well, as the ring-gear/flexplate bottom cover is long gone, a victim of a former owner or quickie oil change place....
